BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
      11-03-2008, 12:20 PM   #1
135i racer
Beamer Boy
135i racer's Avatar
Drives: Soon to be M3, or M6 who knows
changing the springs
hey guys this might be a dumb question but im trying to change my springs and get the h&r springs but do i have to change out the struts thanks
      11-03-2008, 12:35 PM   #2
randomquickness
Drives: 996tt
it is not required but many recommend it
      11-03-2008, 12:52 PM   #3
modbargains
modbargains's Avatar
170
Drives: 08 E90 335i & 01 Toyota Avalon
The struts do not need to be changed, however as randomquickness mentioned it would be recommended. When changing to a lowering spring of any kind, with shortens the travel of the OE strut in turn shortening the life of the strut and cause pre-mature failure.
      11-03-2008, 02:25 PM   #4
marcus
Drives: 2011 135i Vert
I changed my springs a few weeks ago. Lowered 1.2inches front and rear. The rear is easy. On the left side there is a little clip with a rubber piece make sure you disconnect it before pulling down to get the spring out.
The front on the other hand is a PITA. I went without any instructions. once you have the tire off you have to removed the 3 top nuts in the engine bay(leave one nut on loosely.)
Then you have to disconnect the 3 Big struts attaching to the strut/rotor assembly(you will see which ones).
Then removed the bolt attaching the strut to the rotor.
In the front there is also a a clip that you have to disconnect(it is the leveling clip for the lights).
After you have removed everything take a screw driver and pry a little in the gap where the rotor attaches to the strut it might take a little of patience(took me 2 hours for the first one).
Make sure you have a jack ready to rest the rotor assembly on cause it is heavy.
Once you have the springs changed Make sure the top part (with the 3 studs) is still able to rotate.
Then you are ready to install them, make sure you dont forget the gaskets on the struts lol.
But now that you have my 2 cents. I recommend to save up some money and get fully adjustible ones. Its well worth it.
      11-03-2008, 02:43 PM   #5
135i racer
Beamer Boy
135i racer's Avatar
marcus
thanks for the info any pics on the drop you did
      11-03-2008, 03:54 PM   #6
randomquickness
Drives: 996tt
here are some pics of my drop
http://www.1addicts.com/forums/showthread.php?t=17221
      11-03-2008, 05:23 PM   #7
BMW F22
BMW F22's Avatar
Drives: ///M235i
It's usually recommended that you change both the springs and shocks at the same time. However, if you really don't want to, you can just run springs for a while and then buy new shocks. You will have to pay again for labor though.
      11-04-2008, 12:20 AM   #8
marcus
I will try to make some, but 1.2" is a perfect drop i think.
      11-06-2008, 09:59 PM   #9
stunn2night
no tire gaps
Armenia
Drives: 135
i would do the struts too, any pics on what ya got ?
      11-07-2008, 12:41 PM   #10
SV Concepts III
Drives: BMW Duh
You don't have to change out the struts, especially on such a new car Just be aware, however, that the stock struts will wear more quickly with aftermarket springs so you will have to replace them eventually. If you have the funds for new struts, I would do it at the same time as you will get better handling out of a full replacement system. With that said, if you are mainly interested in lowering the car and firming up the ride a bit, go with a set of springs- H&R is a fantastic choice.
1addicts
