BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
      11-09-2008, 04:47 PM   #1
bluemoon
Drives: 135i
Racing Brakes
Can someone explain why give the same rotor size, pad compound and hi-temp brake fluid will calipers designed for racing perform better than the fairly robust ones on a 135i...sans the ceramic piston insert that is.
What makes racing calipers stop a car better and fade less?
      11-09-2008, 06:06 PM   #2
WAY
Australia
458
Drives: Fast ones
The design of the calipers makes a huge difference. Stiffness and weight are two aspect that makes a difference. Flex can be reduced by the number of bolts that hold the piston together (and where they are placed), whether it is monobloc or not, materials used etc. Another thing that a good racing caliper design does it direct the fluid piping away from the rotor which generates a lot of heat.
      11-09-2008, 06:23 PM   #3
professor
Drives: Z4 M40i
:wink: :respekt:
      11-09-2008, 06:49 PM   #4
bluemoon
Drives: 135i
Good info...
1addicts
