11-13-2008, 09:40 AM | #1 |
Rep 1,288
Eibach Pro vs H&R Sport Springs ???
So which ones seem to be the preferred choice?
Background....no need for coil overs. I have my e36 and e30 on completely revises suspensions. For the 1er, just looking to keep close to stock, but lower it and take out some of the floaty feel. Plan to keep the OE shocks. Based on previous info from Larry, sounds like the H&R Sports are not specifically designed for the 1er. Larry indicated the part number is the same as the E90. (Correction, looked today, and H&R Sport p/n 29187 seems to be only for the 1er and not shared among the e90 chassis.) Whereas I beleive the Eibach is specifically tuned for the 1er. This sounds like a big plus for Eibach. Thoughts? So, H&R sports or Eibach Pro? Thanks fellow addicts! Mark M |
11-13-2008, 01:11 PM | #2 |
HALA MADRID!
939
Rep 2,879
both are great. I've used the Eibach Pro and Sportsline in my previous cars, and I'm currently on H&R sports with the 135i.
the H&R used to be stiffer than the eibach, but surprisingly on my 135i it is very comfortable.....the big thing is that the H&R has a Massive drop in the front! 1.8" and it looks more like 2"!! the eibach Pro is nowhere near that. if you want a slight drop, go with the eibach....if you want a very aggressive drop, go with the H&R sport.
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
11-13-2008, 02:18 PM | #3 |
Rep 9,788
The Eibach will give you the least drop and thus is a little less aggressive. If you're planning on keeping your stock shocks, I would recommend the Eibach (although the shocks would still go out much quicker than with stock springs).
11-13-2008, 02:41 PM | #4 |
Rep 365
I had the Eibach Pro Kit Springs installed with Koni Sport shocks last weekend and will be reinstalling the stock springs this weekend because I feel that the Eibachs are too stiff. If anyone wants to buy the Eibachs, I'll sell them to you for $175, plus shipping. I paid $235.
11-13-2008, 03:06 PM | #5 |
Rep 378
I have the Eibachs, yes they are alot stiffer than the stock so I hope you dont haave bumpy roads where you live, cuz I do. I got used to it by now the body roll is much less, but if you are a person that gets aggravated by a rough ride......dont get the Eibachs.
11-13-2008, 03:22 PM | #6 | |
Rep 175
Do you have some pics of your car on H&R springs?? Im expecting to install these, and would like to see how the drop fits the car. Thanks. |
11-13-2008, 03:46 PM | #7 |
Rep 1,288
Ok, so from this small sampling...it would seem the Eibachs might be a bit stiff for daily use. While H&Rs are compliant for daily use, they are aggressively low in front.
So any thoughts on using thick spring pads with H&Rs so as to keep from having too huge a drop? Extra thick spring pads in the BMW parts bin for the 1er? Thoughts? thanks. |
11-13-2008, 03:48 PM | #8 |
Rep 365
Marcus, do you have the Eibach Pro Kit springs or the Supersports?
11-13-2008, 03:58 PM | #9 | |
HALA MADRID!
939
Rep 2,879
11-13-2008, 06:15 PM | #10 |
Rep 17,017
Both are solid setups, you cannot go wrong either way. The Eibach will give you a more even drop, the H&R will be more of a raked look. I prefer the H&Rs over the Eibachs but I don't think there is a wrong choice.
11-13-2008, 08:51 PM | #11 |
Rep 4,311
Drives: Supercharged E90 M3
Guess ill be going with H&R's.
:biggrin:
11-14-2008, 08:01 AM | #12 |
Rep 652
Running H&R Sport springs. Drop was definitely a bit more than I anticipated, but I love the look. Ride is still very good for everday driving. I believe H&R now has 3 different spring choices. OE Sport, Sport, & Supersport.
11-14-2008, 11:56 AM | #14 |
Rep 17,017
That's a perfect drop if you ask me, I love the raked look.
11-14-2008, 12:14 PM | #15 |
Rep 378
I have the Pro kit. -1.2front and rear. perfect drop IMO
11-14-2008, 12:32 PM | #16 |
Rep 365
Great thanks. Does it feel like the suspension bottoms out over the hard bumps? Mine feels like it bottoms out, but it could just be too much high speed compression damping causing hydraulic lock. I'm hoping that going back to the stock springs with the Konis will cure the harshness, but still improve the body roll and mushiness of the stock set-up.
11-14-2008, 12:35 PM | #17 |
Rep 4,311
Does anybody have pics of the Pro kit installed?
11-14-2008, 12:36 PM | #18 |
Rep 365
11-14-2008, 12:41 PM | #19 |
Rep 365
Try taking a look at these pics: http://www.1addicts.com/forums/showthread.php?t=4479
11-14-2008, 12:46 PM | #20 |
Rep 3,160
As already mentioned, both are a great, solid set-up. I would personlly go with the H&R though, the look and feel that it gives is very planted.
11-14-2008, 03:03 PM | #21 |
Rep 4,311
Roger, im not sure if i like the raked look, with the pro kit, you get a even drop...
Maybe ill go with the pro kit. Do you guys sell them Roger?
11-14-2008, 03:15 PM | #22 |
Rep 4,311
It's where the front of the car is lower than the rear.
As seen here: Still a sexy car tho.
