BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
European Auto Source (EAS)
      02-27-2010, 08:22 AM   #1
awells93
awells93's Avatar
Drives: 2015 Spaceship
Removing exhaust tips, rivetS?
Do the rivets just pop off of the 4 tips?
2010 AW/Black E92 M3 retired
2015 MG/SO F82 M4
      02-27-2010, 02:16 PM   #2
SOCAL
Drives: E92 M3
yes, four rivets per tip. Drill them out and twist the tips off.
      02-27-2010, 02:44 PM   #3
awells93
awells93's Avatar
alright thanks man
2015 MG/SO F82 M4
      02-27-2010, 05:35 PM   #4
JCtx
Drives: No BMW yet
Originally Posted by awells93 View Post
alright thanks man
Just keep in mind we're supposed to use 'full stainless steel' rivets (per SOCAL), and they alone run $30 (plus rivet gun, or another $30).
I asked our friend SOCAL if we could use aluminum, since the rivets' only job is to hold tips in place (zero shear force, etc), but he never replied. Maybe somebody else can answer that. I want to remove the tips before powdercoating my muffler for extra safety, but not if it costs $60. Take care.
      02-28-2010, 03:00 AM   #5
swamp2
swamp2's Avatar
Drives: E92 M3
Not quite... Check out McMaster Carr (www.mcmaster.com). I don't have the size exactly but made a good guess and found SS rivets for $12/100. I bet aluminum ones would be just fine as well. Aluminum ones will run about 25% as much. They also have rivet tools for $25. We here in So Cal can get next day UPS ground shipment from them.
You might be able to find them in quantities of less than 100 in a local specialty hardware store as well. Either way <<<<<< aftermarket exhaust.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      02-28-2010, 02:21 PM   #6
JCtx
Drives: No BMW yet
Hey man, that's exactly the place SOCAL suggested. In fact, the correct rivet he used was this one: 97550A210. And the tool he recommended was this one: 6659A21.
I believe he has the right rivet dimension, but I was hoping for a less expensive alternative. If you found one that fits properly, like those 100 for $12, can you please post the part number? Check out the above number for correct size. Thx.
      07-14-2010, 09:24 AM   #7
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
I just replaced my tips with black BMW chrome tip and cost me a total of $5 bucks
So i bought a revit gun at home depot for $10 bucks then bought the revits (aluminum) for $5 bucks
Its only a bitch when taking the revits out cause ur going to end up using different size of drill bits
Once i was done i returned the revit gun refund of $10 bucks well i really have no use for them so returned it.
      07-15-2010, 10:50 PM   #8
GregW / Oregon
Commander-In-Chief
2122
Drives: 2023 M2 Coupe, 2020 GLE 450
"Revit": http://usa.autodesk.com/adsk/servlet...112&id=3781831. I don't think you bought these at Home Depot. That's what I use at work and it's more like $5-6k.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      07-15-2010, 10:57 PM   #9
GregW / Oregon
Commander-In-Chief
2122
Dissimilar metals and corrosion
Stainless is the correct rivet material for stainless, as any dissimilar metals have some galvanic reaction (meaning they corrode with exposure to moisture) over time. For "harsh environments" subject to moisture there should be no more than 0.15 difference between the metals' anodic index (see following chart). For stainlesss and aluminum it is aobut 0.25 - 0.40, depending on the aluminum composition. In the real world, for this non-critical installation, it's not a big deal, but I would probably still pay a few bucks more and get the sst myself. The other option is to go with a factory painted rivet which prevents the metals from coming in direct contact (I know you can buy white ones).
      07-30-2010, 11:39 PM   #10
deletedelete
deletedelete's Avatar
Drives: m
So do you drill into the middle hole in the rivet, or put the drill bit covering the entire rivet? Ive never drilled a rivet before. Rivet......cool word.
      07-31-2010, 03:19 AM   #11
kmarei
kmarei's Avatar
Egypt
687
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
i only use gold rivets
0.00 anodic index baby!
      08-01-2010, 11:37 PM   #12
lvwirelessguy
Drives: 2011 E92 M3, 2012 Golf TDI
2005 M3  [0.00]
Can you replace the tips without taking off the exhaust?
      08-02-2010, 12:18 AM   #13
deletedelete
Drives: m
I just made a thread asking this as im wondering too.
      08-02-2010, 12:22 AM   #14
Gyoung
Drives: E92 M3 & C219 CLS55
I am wondering too
      08-03-2010, 12:46 AM   #15
GearRex
GearRex's Avatar
Drives: G80 M3, E46 ZHP, 991.2 Cabrio
I don't think there is a way to drill out the rivets without taking the exhaust off the car. There are 2 rivets within easy access from below, but the other 2 rivets between the exhaust and the heat-shield are impossible to get at. There is no way of squeezing a drill in there!
I read this DIY about removing the exhaust, it is a 90 minute job. it seems to be the only way.
http://www.m3post.com/forums/showthread.php?t=299777
If anyone else has a way to remove the tips without removing the exhaust, I am definitely interested.
      08-03-2010, 08:20 AM   #16
GregW / Oregon
Commander-In-Chief
2122
I haven't tried this, but once you drill out the accessible side maybe you could just keeip drilling through the pipe and through the other side:? Centering on the far rivet from inside would be tough, though.
      08-03-2010, 10:49 PM   #17
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
No
      11-27-2010, 09:32 PM   #18
ruda001
Drives: 2008 BMW M3
No
I just changed mine and would definitely say you can't...will post some pics later.
      11-27-2010, 09:52 PM   #19
GregW / Oregon
Commander-In-Chief
2122
Exhaust upgrade
Best solution is to think big and just switch out the crappy stock unit, IMO.
      11-27-2010, 09:54 PM   #20
GregW / Oregon
Commander-In-Chief
2122
That only make the delta higher?
      11-27-2010, 10:18 PM   #21
kmarei
kmarei's Avatar
Egypt
687
That only make sthe delta higher?
I was joking
I was mocking the whole bling mentality, you know like gold teeth etc
      02-07-2011, 03:15 PM   #22
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
NOT TRUE.. aluminum will do just fine just make sure you have the correct size then your OK....
m3post
