BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
BPM
      04-22-2010, 01:06 PM   #1
formgen99
formgen99's Avatar
Drives: 2014 535i
e93 dome light disassembly to install F1 Autohaus LED kit
The e93 dome light isn't like the e90/92 with a removable lense cover, you have to take it apart. I didnt see anything on the internets so here ya go.
Once you get it down you will need to remove 10 torx bit screws size T8 on the backside.
Then take off the black plastic cover, next remove the green board, then remove black trim piece, finally you can pull out the reflector to install the 12 led board from the F1 Autohaus kit.
Put it all back together in reverse order.
2014 535i
Past Vehicles
2011.5 E92 M3, 2009 E93 M3, 2008 335xi, 2004 Mustang GT,....
      04-22-2010, 01:28 PM   #2
Mike@F1 Autohaüs
Mike@F1 Autohaüs's Avatar
195
Drives: ❤
Great contribution to the forum
      04-22-2010, 07:20 PM   #3
JCtx
Drives: No BMW yet
When I removed that console on my E92 M3, it looked identical to yours, with the 3 bulbs in the same location. The 'dome bulb' is the middle one, but yeah, if you want to install an LED board, you need to take it apart like you did. Your instructions should apply to all E9x cars then .
By the way, a helpful hint to remove the console itself: remove the 2 bolts securing both sun visors (where they 'clip') to allow headliner to come down enough to easily stick your fingers from behind and push the forward console clips to release the console from the roof bracket. The clips are located right in front of each map light, so you know where to direct your paws . Hope this helps.
      04-23-2010, 06:30 AM   #4
formgen99
formgen99's Avatar
Drives: 2014 535i
To get mine down, I stuck my finger in 1 of the map light holes and gently pulled it down and toward the windshield. That brought it down far enough to see the metal clip on that side and then I used a flathead to push the metal clip in on that side and then did the other, then the whole thing came down.
Also, there are 2 plastic tabs on the right side that need to be depressed to get it out.
2014 535i
Past Vehicles
      04-23-2010, 07:16 AM   #5
rwchrist
CMPULSV
rwchrist's Avatar
Drives: 09 Alpine White
2009 M3  [0.00]
Wish I would have seen this yesterday around 4PM cuz I could not find those damn tabs. Anyway, once the headliner was loose, I was able to fit my hand inside and twist the bulbs out and replace them. For the middle one, I just popped the frosted lens off and mounted it...it was a mother to get that lens back on.
2009 Alpine White DCT E92 M3 - Tint, Hood M Stripes, Eibach Springs,
Gloss Black Rims, Vorsteiner Lip, BMW Performance Trunk Spoiler
Fabspeed x-pipe & Megan Race Exhaust
2006 Imola Red 6-speed E46 M3 - Retired
      08-26-2010, 10:23 PM   #6
Euro_E93
Drives: '09 E93
How exactly do you get the whole thing down? I got all the metal clips released but it's still held by extended plastic from the housing......I couldn't push in or anything......please help
      08-28-2010, 09:42 AM   #7
Euro_E93
Drives: '09 E93
anyone w/ e93 please chime in..........
      05-09-2011, 05:45 PM   #8
M3Cabrio
BMW God
M3Cabrio's Avatar
Drives: '88 E30, '11 E93, '00 Z3
I just finished install my V-1 in an E93, the light fixture drops down by placing a finger in the spot light and gently pulling down. Use a flat screwdriver to press in the metallic clips. Then, i pulled down firmly on the right side to pull the unit out past those plastic clips on the side; it came out without any issues.
I saw 2 torx screws holding the mirror in, I used one for the ground. The green with white stripe wire provides power when the engine starts.
Simple, quick, and easy. Thanks for all the DIY info.
m3post
