      05-06-2010, 07:58 AM   #1
dbtk
Drives: BMW 135i
M1 tire sizes?
What are the anticipated tire sizes (front and rear) of the new "M1"?
2010 Mercedes GL350 Bluetec l 2009 BMW 135i DINAN l 2007 Mercedes CL600 l 1997 Porsche 993 Turbo l 1972 Mercedes 600
      05-06-2010, 08:14 AM   #2
Drillslinger
Drives: BSM 1M / R53 / E91
Since it's using the same f/r track as the M3, wouldn't the M1 (1///M or whatever) use the same size tires?
Vorsprung durch Gas Geben!!
172 of 740
      05-06-2010, 10:26 AM   #3
ptack
ptack's Avatar
Drives: 135i
2008 135i  [6.50]
We can only pray that is true, but the current 1 offsets are one-offs so don't be surprised if the uniqueness continues.
135i, SGM, Coral, Sport Package, Auto, Premium Hifi, USB/ipod, Apex EC-7s, PPK Stage II
      05-06-2010, 10:44 AM   #4
oztiks
oztiks's Avatar
20
Drives: 2015 435 Gran coupe
275's up front and 305's in the rear ...
      05-06-2010, 10:52 AM   #5
Drillslinger
Good point, but if they're reworking the wheel wells/fenders anyway....
172 of 740
      05-06-2010, 11:23 AM   #6
Cornhusker
Drives: 335i
I vote 265/245. However I hope for 275/255. Aftermarket you'll be able to go at least two sizes bigger back/front so at least 285/265 I bet.
      05-06-2010, 04:12 PM   #7
amdmaxx
My gift Registry: M2
amdmaxx's Avatar
Drives: Future Mowner of Monster
How will the winter setup look?
Will M1 be terrible even with winter tires if they are on the wide side?
For summer, I would want to see a staggered deep dish setup.
      05-06-2010, 08:04 PM   #8
grant
grant's Avatar
Drives: 1973 Porsche 911
You'd definitely want to use a separate set of narrow wheels to go with your snow tires for best winter performance.
1973 Porsche Carrera RS 2.7 Carbon Fiber (240hp & 1,890 lbs)
      05-07-2010, 07:27 AM   #9
BMW269
I think M3 rims with M3 tires will fit. But it will maybe not go in to production with 19" but 18".
      05-07-2010, 07:49 AM   #10
///Mangler
///Mangler's Avatar
334
Drives: E30 M3 Darth Vader Trackcar
2000 E39 M5  [9.00]
square 255/18 setup for me.
T
      05-07-2010, 08:47 AM   #11
BMW269
T
Could you explain me the differences, pro/contra of 245 front/265 rear and 255 square?
      05-07-2010, 09:41 AM   #12
Cisitalia
No fast lane bandits allowed
Cisitalia's Avatar
Drives: 2009 135i TiAg 6mt M-Sport
Less understeer in a square setup. Also allows front:rear tire rotation that is especially usefull for when driving on the track. Allows for more even wear distribution. BMW won't do that though, since they want induced understeer for the bad drivers out there.
I would appreciate a square setup, but I would want it wider than 255. I think 275 square would suffice on this car.
      05-07-2010, 02:03 PM   #13
///Mangler
///Mangler's Avatar
334
2000 E39 M5  [9.00]
This^^^, but 275 is getting heavy. You want unsprung as light as possible and if they can lighten the car 255 will suffice.
T
      05-07-2010, 02:40 PM   #14
BMW269
Ok, thinks. But Audi has sqare setup and understeer. Is it because of AWD?
      05-07-2010, 03:42 PM   #15
Muffnbluff
Redline Addict
Muffnbluff's Avatar
Drives: '14 BMW 335 xdrive
Not if they're just robbing the //M3 parts bin.
      05-07-2010, 04:03 PM   #16
Cisitalia
Cisitalia's Avatar
Yes and those cars are front heavy which also induces an extra dose of understeer.
T
Not quite, if that was the case people would put bicycle tires on. Yes less unsprung weight is an admirable goal but not at the expense of tire width. That single factor alone can greatly increase handling capability, but only to a point. There is an optimum and certain amount of compromising required. The handling benefits of 20mm wider tires are greater than loosing 2 pounds of unsprung weight per corner on this car (Mich PS2 255/35-18 25# vs. 275/35-18 27#).
If the car was 3000 lbs. and less than 300hp, than a square 255 setup would suffice. But this car begs for the square 275 setup, especially for the track. Hoosier R6 275/35-18 at 23# would be an awesome square setup for the track on some light wheels.
      05-07-2010, 04:14 PM   #17
JimD
JimD's Avatar
368
Drives: 128i convertible
If we assume that the M1 is getting the M3 LSD rear end, it would turn higher rpm - for quicker acceleration and worse gas mileage - if it uses the same 265/40 series rear tires (because the M3 LSD is a 3.85 ratio versus the 3.08 of the 135). They could change the ratio but I wonder if they will with the M1 being, presumably, a limited volume vehicle. Rpm of this combination would be over 2500 at 60 mph - only a little lower than the M3 (which has a .87 6th gear versus .85 in the 135).
I don't know if they'll set it up this way, the 135 doesn't need the rpms to make power the way the M3 does, but it will be a very quick car if they do.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      05-07-2010, 04:44 PM   #18
///Mangler
///Mangler's Avatar
334
2000 E39 M5  [9.00]
I don't think you will get 275's up front from BMW, plus those 2lbs are as far out as you can get on the wheels so you suffer momentum/braking losses also. These are things that have to be tested on track to find the happy compromise between grip and handling. Bigger is not always better.
T
      05-07-2010, 06:01 PM   #19
Cornhusker
Drives: 335i
Agree, but I still bet on 265/245 stock.
      05-07-2010, 06:11 PM   #20
Cisitalia
Cisitalia's Avatar
T
Totally agree. BMW will go stagger like you indicated. I am only thinking of a track setup.
1addicts
