ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Track / Autocross / Dragstrip / Driving Techniques
  TireRack
SUPPORT ZPOST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
      06-12-2010, 10:10 PM   #1
jbh
jbh's Avatar
18
Drives: 2007 Z4M
What to do on Z4M for AutoX
Hey everyone,
I just purchase a 2007 Z4M roadster today and will pick it up Monday. Long story short, I thought I was going to buy one last year but talked myself into the cheaper 2006 350Z roadster, but I have been missing the M engine ever since so I fixed that today.
I have been AutoXing the 350 quite a bit, with some time trials also. Just for some background - it has a little understeer from the factory with staggered setup 225/245. Only thing I did was go square 245x4 and it took some out but still has a little, nothing the throttle will not fit. I also ran on Z1 star specs and really liked them.
Now I am getting this Z4M and I understand it has quite a bit of understeer stock. What do you suggest to get the car somewhat competitive (the 350Z was really not that competitive but I was generally 2 seconds away from really fast cars (except Z06). I plan to get a second set of wheels to run star specs on for events on the Z4M. What size tire setup will dial out the understeer to make it more neutral. Also I understand I can take out the alignment pins to get a little negative camber in front, but will that be enough? I am not really worried about SCCA classing because I usually run with PCA, BMW, S2000 group, so they have their own classing.
I don't want to go too crazy because I really want to do this on the cheap and in a year buy a cheap miata to make as a pure track/autoX only car. I want to keep the Z4M as a comfy daily driver. But I don't think I can stay away from racing for that long so I better run the Z4M.
Let me know what you guys think.
      06-13-2010, 02:44 AM   #2
jdl1pt
Drives: Z4M coupe 2007 IL Blue
Hey jbh, congrats on the new purchase. I just autox'd mine today for the first time, had a blast, but yes a lot of understeer. Here is a paragraph finnegan email me a few days ago. there is a great link in there that talks about tire set up, etc.
Hopefully this will be a good jumping off point for you:
this is the link to the thread mentioned below: http://www.zpost.com/forums/showthread.php?t=367909
Have you seen our "dead tires thread"?It's a pretty good primer on our journeyaround tires, alignment, understeer, etc. The stock setup of the car is way too oriented to understeer due to insufficient front end negative camber. Max you can go, with the pins pulled, is about -1.0. Then it's camber plates or some E36 washer/bolt combos that can dial in more in .5 degree increments. Have the washers on order from Turner (want about -1.5% to balance the -2.0 in the rear), and the CDV (clutch delay valve) delete on the way from Zechausen Racing. (Car, used, had +.01 on the passenger front, damn it sucked at speed....) Hate that CDV--makes me look like I can't drive stick worth a damn every now and then.
      06-13-2010, 07:59 AM   #3
jbh
jbh's Avatar
18
Drives: 2007 Z4M
jdl1pt,
Thanks for the reply, lot of good info but no definitive tire stagger setup. Sounds like the 245/265 would get me close.
I am new to the M so what is the CDV?
      06-13-2010, 10:25 AM   #4
Shorestyle031
Shorestyle031's Avatar
39
Drives: 08 M roadster
The CDV is a clutch delay valve. Sometime when shifting hard 1st to 2nd it wont allow you into gear and makes a grinding noise. http://www.zpost.com/forums/showthre...&highlight=cdv
08 M roadster
      06-13-2010, 11:32 AM   #5
jdl1pt
Sorry, wish I could give you more insight. I will tell you that many on here run 255/275's. At the even yesterday, one of the instructors, who was driving a caymman, also has a z4m. He has tracked his z4m a few times. I told him I had 235/265's ready, and his comment was, "next time go with the 245/275 set up, they'll fit." Ultimately, he thought that was a better set up for autox. The other big issue is the camber both front and rear. I understand pulling the pins will only get you so far. to get 1.5 - 2+ you'll need to go with washers or plates. You could probably also get more if you dropped the car a bit, but that's getting pricy.
Lastly, from what I've read here, a strut bar will greatly help turn in. This is probably going to be my first addition. You can pick one up from tischer for about 300.
I'm gonna take me car out to a highly respected tire/race shop here in the next few weeks to have the new tires installed and start working on a camber setup. Once I do, I'll report back with their recommendations at that time and let you know what transpired.
      06-13-2010, 03:30 PM   #6
Finnegan
Dog Listener
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
With pins pulled You'll get -1.5 if you're lucky. -1 seems to be about average (what we got with pins pulled). For more, it's either camber plates or use the Turner bolt/washer for the e36. (The Z4M front end is based on the E36, not E46.) Washers work, but there's a bit of debate on that one since it does also change other aspects of the geometry.
My wife's car (the ///M), stock, before tires/alignment was running close to zero both sides front and plowed for days. With the Star Specs and -1 front, it's much better. But remember stock is much less than -1 front and probably around -1.5 rear if I recall. Car, stock, with pins out in front is now -2 rear, -1 front. Pretty decent for street driving, not aggressive enough for anything else.
Mmmm, maybe. Can't say from experience, as we don't have one. Now, according to some of the experienced folks on this board (no that's not me, and you know there's never consensus--it's an internet forum ) it will help a bit but don't expect a great difference. Strong strut makes a pretty good option to OEM from Tisher, but OEM is pretty good too. Word is stay away from Dinan for this as those have "flex joints" and really are questionable in terms of impact.
I think pins, washers, plates would be where I'd start. I just ordered the washers (cheap) and we'll see. But, tell you what, if you start with the strut bar, I can start with washers, and we can compare notes!
I just wish we could find a nice big open parking lot and set up a mini course with some chalk and have at it! We could so use that kind of practice. I'm glad you autoxd it yesterday rather than doing that drive with us. The drive, while fun, was super challenging and not one where you'd want to discover the unique handling characteristics of this car for the first time. I would not have been happy if I had done that drive without the car control clinic first and a good amount of seat time first. See my PM.
Here's a good thread on suspension Rick Hunter pointed me to. I understand that the GC camber plates are a PITA to adjust on the fly, and adjustments are opposite of other plates. An option, to the GCs (which are very good mind you, just have those two things about them we should know about) are the Vorschlag Camber/Caster Plates per Rick, they're just as good or better than GCs at a similar price too.
      06-13-2010, 05:23 PM   #7
Serious
1M advocate
Serious's Avatar
Drives: 2018 S4. 2011 M3. 2012 S1000RR
As others have said... CAMBER CAMBER CAMBER.
Sucks for autox because you are restricted to A stock IIRC, and thus can't run camber plates which is what the car really needs.
Best bet is pulling the pins and shimming the lower bolts.
You can also run something like I used to run on my e46 m3 which was 245/255 tire setup to minimize the understeer, and get closer to a square setup.
2012 BMW S1000RR
2011 BMW M3
      06-13-2010, 09:26 PM   #8
jbh
jbh's Avatar
18
Drives: 2007 Z4M
If I do the lower bolt and washers thing to dial in more does that bump me out of A stock? I know the camber plates would put me in a class I don't have enough money to compete in.
Really though I am not running SCCA events generally at all so it probably does not matter, I was just wondering if the bolts and washers would put me out of A stock.
245/255 sounds interesting, did the car feel pretty neutral or did it turn into more oversteer than understeer? I am looking for pretty neutral, understeer is not as fun. This would just be my event setup, I would go back to the stock understeer tires for daily driving 225/255.
Thanks for all the replys - I don't even have the car yet. I pick the car up tomorrow assuming nothing is wrong that I did not see yesterday. It has been a long 2 days waiting.
      06-13-2010, 10:01 PM   #9
Finnegan
Dog Listener
Finnegan's Avatar
2010 SCCA rules, see bottom of page 75 and 76. I don't know whether washers are a "modification is specifically authorized by the factory shop manual for non-competition purposes." I don't know if it's really anything to worry about if you use them (not easy to spot like plates) and don't go too crazy--especially since it sounds like you would go with a more square setup for autox and revent to staggered for street. Maybe -2.0 on the front with washers and a square or squarish setup for autox? W/O pins some folks claim to have reached -2.0, so getting to -2.0 isn't beyond what the stock setup will support, in some cases--maybe I'm being a bit "flexible" in my interpretation of things however....
      06-13-2010, 10:30 PM   #10
fitchesbass
I ran last autox season with stock conti's add they were pretty miserable and greasy... compared to my previous E36 M3 which had goodyear eagle F1 D3-GS's.
Star Specs on our lemons car seem really grippy thus far and I've enjoyed them in the testing we've done. I'll let you know how they hold up after this weekend and thrashing on them for almost 24 hours
In terms of tire widths and playing around with that... I haven't had time to experiment with that on the Z4.
But you can certainly induce some idiotic power oversteer if all else fails... LOL. Just watch what tires you chose in terms of the rules and class you are running in (e.g. width's, treadwear, etc)
911 Carrera project car
Previous:
E92 M3 ZHP - Sold
E86 Z4M - Sold
E36 M3 - Sold
      06-14-2010, 09:06 PM   #11
F360C
Drives: E86 S54
It is possible to get around -2 in the front with just the pins pulled but it takes a good alignment shop. I was able to get -1.9 on both fronts where as my bro was able to get -2.0 on the passenger side and -1.9 on the drivers side. He settled with -1.9 because no matter what they tried they could not get the other side to -2.0. I also used the turner camber bolts (really just a glorifed washer kit) for a summer of tracking and liked it. The extra bit of camber we were able to get vs other people might also be due to the fact that we both had H&R springs on.
At my current -2.5 I am able to fit 255/35/18 R888s in the front on the stock 18s but It does require a spacer. I use a 15mm spacer because its what I have for my ZCPs but you could really get away with a 10mm or less. The 15mm does look bad ass though and I actually have less rubbing with 15mm spacer and the 255s then I did with the 245 and no spacer. In fact I actually have no rubbing at all with the 255 set up... most likely due to the slightly shorter 255/35/18 tire
07 Z4 M Coupe AW/IR
      06-15-2010, 01:23 AM   #12
Finnegan
Dog Listener
Finnegan's Avatar
Good to know. Any kind of lowering spring is going to give more negative camber, so like you said, that helped get you to -2.
"Glorified washer set" But yeah, that's what it is alright! I'm shooting for -1.5 or a tad more since this us primarily a street car. We'll see how that runs (and wears on the tires) and continue to adjust from there.
      06-15-2010, 06:46 AM   #13
jbh
jbh's Avatar
18
Drives: 2007 Z4M
Just got the car yesterday, what a huge improvement over the 350Z. So much more refined of a car. It will take me a little bit to get familiar with the car but hopefully I will take it to an event sometime within the next month or so. Lets keep this thread going for you guys who are making adjustments - report back on how it works for track and also how it effects daily street driving.
I will be looking out for some wheels now to use. Anyone need a set of wheels with star specs mounted for a 350Z/Infinity G35 coupe?
I noticed in my manual some cars have a data logger, so BMW is watching us and recording data? Any chance it could be used against us for warranty claims if they said it was used for track/autoX. Probably not what they intended.
      06-15-2010, 06:48 AM   #14
jbh
jbh's Avatar
18
Drives: 2007 Z4M
They just had the lemons race by me at Eagles Canyon 2 weeks ago, that looks like a good time.
      06-15-2010, 07:31 AM   #15
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Good to hear you got your car and like it. I've had mine for about 2 1/2 months and I feel very comfortable driving it but I refine driving it everyday. This car is a little tricky to get the hang of, between the touchy clutch and the very direct steering, it takes so fine tuning of your driving skill to make it behave exactly how you want it to. I was planning on hitting some local tracks this summer but have been hella busy trying to find a new place on the weekends. There are lots of good track events coming up in our area. Check DFWautoclub.com events section for local DFW action. Hope to see ya around!
      06-16-2010, 12:22 AM   #16
jdl1pt
Just curious, how much lowering did you get front and rear with the H&R spring set?
      06-16-2010, 07:34 PM   #17
F360C
Drives: E86 S54
It was a bit of a understatment when I said "glorified washer kit." I bought the turner kit over just using washers because I like how the spacers bridge the gap between the two strut bolts. It just seemed worth the price because of how it was a more structural part.
I have no need for my kit any more so if you want it you are more then welcome to have it for free... you just gotta pay for shipping which shouldn't be much.
I would say it was about 0.8-1.0 inch
07 Z4 M Coupe AW/IR
      06-27-2010, 03:11 PM   #18
jbh
jbh's Avatar
18
Drives: 2007 Z4M
Holy understeer!!
I just got back from my first AutoX with my local PCA club. Car is totally stock with stock tires as well.
Next event I am putting on my 4 245/45 R18 2/3 used up star specs on my second set of M wheels and then try that out. I could definately tell the stock tires are not as sticky as the star specs. I really thought my braking sucked but I think it was just the low grip of the tires. I am probably going to go from understeer to oversteer but thats ok, I already own the tires so its not like its costing me anything to try it out. I then need to get some negative camber by pullin the pins and getting an alignment, maybe using the washer kit.
I did feel like the back end stuck pretty good coming out of corners with throttle. I guess the M differential is a good one.
If I had to guage it I would say I was 1.5 to 2 seconds slower on a 45 second course vs the 350Z with the square star specs setup. Hopefully the different tires will bring my times down.
Anyone else had a chance to try out any of their changes?
      06-27-2010, 08:38 PM   #19
03BeastCharmer
03BeastCharmer's Avatar
257
Drives: '13 M3
Def do the washers. Pulling the pin may not gain you anything as it's very car dependent. Some (including me) could only get about -1 with pulling the pin, but using a washer helped a lot. I'm not sure I'd like a 245 square setup as the rear can get loose with my 275 Star Specs, so 245's would be worse.
Switching out the Conti's for Star Spec's improved my time about 1.3sec on a 60ish second course relative to my class competition, so I really am not a fan of the Conti for trying to be competitive. They help you learn car control as you try to manage your tires, but your not fast.
Current: '13 E92 M3 Euro Delivery
Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3
      06-27-2010, 09:20 PM   #20
jbh
jbh's Avatar
18
Drives: 2007 Z4M
So how much camber do you run with the washers? Any negative effect on daily street driving?
Yes the 245 square setup may be a little overboard but after today I will take loose over tight. I assume your running 245/275 setup?
Thanks.
      06-28-2010, 12:50 AM   #21
Finnegan
Dog Listener
Finnegan's Avatar
Thanks.
You should be able to get about -2.0 with the washers--you can probably add one more and take it to -2.5.
Just had Skelekitty's ///M aligned and used the Turner bolt kit, and they put the washer kit on before alignment. The prior alignment, barely got to -1.0, with just the washers and before they dialed in changes the camber in front was -1.9. I had them dial things in front to -1.5, and went -1.8 rear. -1.5 compared to -1.0 is very noticeable--the turn-in is so much crisper and sharper it's not even the same car!
We'll see how SK likes this, and if she wants more we'll go -2.0. That's as far as I really think we want to go with street settings--but I can see where you'd easily want more (like maybe even -3.0) for autox. I'm pretty sure you can't get that w/o plates though, which would put the car in another class. But I'm impressed with how the .5 change up front really makes a difference! It's so much sharper and responsive! The "stock" setup when we got the car was -.1 up front--which was understeer/plow city. Damn it was bad; going to -1.0 with pins pulled was better; -1.5 is better yet.
Alignment:
Front:
Camber -1.5
Caster: 6.0
Toe: .08
SAI: 15.6
Included Angle: 14.1
Cross Camber: 0
Cross Caster: -0.5
Cross SAI: 0.3
Total Toe: 0.17
Rear:
Camber: -1.8
Toe: .22
Cross Camber: -0.1
Total Toe: 0.43
Thrust Angle: 0.01
Oh, also had the CDV deleted...wonderful mod. Much easier to modulate and control the clutch and drive smoothly! I highly recommend both mods (Turner washer kit and CDV delete).
Hey, I meant to thank you for the offer! I'd already ordered the kit though. If you still have it maybe JBH would be interested. Looks like he probably needs that washer kit
      06-28-2010, 01:04 AM   #22
Skelekitty
Skelekitty's Avatar
42
Drives: '07 Imola Red Z4 MCoupe
2007 M Coupe  [10.00]
Just had Skelekitty's ///M aligned and used the Turner bolt kit, and they put the washer kit on before alignment. The prior alignment, barely got to -1.0, with just the washers and before they dialed in changes the camber in front was -1.9. I had them dial things in front to -1.5, and went -1.8 rear. (I'll scan this in tomorrow). -1.5 compared to -1.0 is very noticeable--the turn-in is so much crisper and sharper it's not even the same car!
We'll see how SK likes this, and if she wants more we'll go -2.0. That's as far as I really think we want to go with street settings--but I can see where you'd easily want more (like maybe even -3.0) for autox. I'm pretty sure you can't get that w/o plates though, which would put the car in another class. But I'm impressed with how the .5 change up front really makes a difference! It's so much sharper and responsive! The "stock" setup when we got the car was -.2 up front--which was understeer/plow city. Damn it was bad; going to -1.0 with pins pulled was better; -1.5 is better yet.
The CDV delete is awesome, but I'm LOVING the camber washers! I have short arms (even for a girl) and steering around sharp turns was leaving me looking like a twisted rubber band!
~Krissi~ '07 Imola Red Z4 MCoupe
Eisenmann Sport Exhaust | RE X-Pipe | RE Transmission Mounts
zpost
