BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
Mporium BMW
      07-05-2010, 02:42 AM   #1
bavarian06
bavarian06's Avatar
74
Drives: e46 m3
Safe to replace the 35watt H8 halo bulb for 100watt?
Like the thread title says, I want to replace mine with a set of H8 100watt bulbs.
I worry since the factory bulb output it just a mere 35watts. Can someone give me an educated response as what would happen? Would the filament in the bulb simply snap from excessive heat build up or would the whole glass bulb explode? Possibly fry the connecting wires?
Common sense tells me I shouldn't do it, especially since the bulb casing is sealed up with zero ventilation.
Thx in advance.
      07-05-2010, 02:53 AM   #2
badfish
badfish's Avatar
100
Drives: E92 AW M3
2008 M3  [0.00]
Your common sense is good. It would generate so much more heat and I don't believe the wiring was done with enough headroom in mind. I've seen a lot of cars with overwatted headlight bulbs and what usually happens is the wires slowly melt, the bases melt and it makes for some difficult repairs.
Thx in advance.
m3post
