08-26-2010, 10:52 AM | #1 |
Rep 941
kw v2's itching to be installed
So I want to get my KW V2's installed soon but i did not order any camber plates. Do i need them if i plan to drop my car around 20-25mm from stock height? What amount of neg. camber am i looking at??
What im looking for is a perfectly drivable car that has even tire wear and still handles well while not exactly tracking it.. My drop/coilover upgrade is 50% looks and 50% handling improvment over stock(hate the body roll).. I will be adding 19" rims to this drop and willing to roll fenders if i have to.. So thats not an issue.. Input appreciated.
JB4, DCI, Digi boost, CSL eyelids, 5% tint, KW v2's. Bastuck 85mm quad w/ berk resonated mids, LED int ltg, Perf SSK, CF int trim, 19" SF-71 rims, CDV mod, BMS OCC, ER+tial charge pipe. AR DP's, Helix IC,meth, drilled slotted rotors
08-26-2010, 11:02 AM | #2 | |
Rep 2,474
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
08-26-2010, 05:50 PM | #3 |
Rep 2,040
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
You sound like your looking for the same thing as me. My car specs are listed in my signature. With the drop and the front M control arms I'm at -0.8degrees front camber (you'll probably be around .5-.7degrees without the M control arms). I plan to increase or decrease front camber somewhat based on how my tires wear. So far so good but I only have a few thousands miles on my new tires.
The rear is a different story as far as wear goes. Without a drop the inside of the rears wear bad. With the drop I'm at -1.85degrees camber. I need the camber to fit my wheels anyways but there's no way to even out the rear wear.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
08-27-2010, 11:11 AM | #4 |
Rep 941
do i need camber plates then?
08-27-2010, 01:26 PM | #5 |
Rep 2,474
I wouldnt suggest them unless its a dedicated auto-x/track car.
