      08-31-2010, 01:40 PM   #1
southlight
Moderator / European Editor
southlight's Avatar
1537
Drives: X3M
1M to use twin turbo N54 - or so tell these pictures
Following Bimmerfile's report and Scott's confirmation, I thought it might be worth to have another look at this picture M3roar brought up:
Originally Posted by M3roar View Post
Anyone else see this or is it just me?
It's hard to see in this picture, but the 1M's exhaust system appears to have center cats in the mid section. Here's a better picture of this:
Zooming into the center cats section (center cats section enhanced for more clarity):
In case you guys are wondering why I'm stressing this, the same center cats in the midpipes appear on the N54 powered 135i (one on each exhaust pipe, marked with a red arrow each):
The N55 powered 135i however doesn't have these center cats as you can see in these pictures, courtesy of black e (see here). Again, the red arrows show where the mid cats would be on the N54 powered 135i:
Hence, I'd say it's not only safe to assume that Bimmerfile's correct on the N54 being used in the 1M, it's also safe to assume that there won't be any change to the turbo layout, i.e. it will keep the N54's (single scroll) bi-turbo. That being said, I have no idea what Scott could have meant then by saying the 1M engine would be a hybrid between N54 and N55. Any thoughts (or corrections for that matter)?
Best regards,
south
Those forums...WHY NOT?
JOIN THE 6MT CLUB GROUP
      08-31-2010, 01:56 PM   #2
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
This makes sense to me. Nice detective work South.
      08-31-2010, 01:59 PM   #3
madfast
Drives: 2010 PB Evo X MR-T
Didnt scott mention early on about a "trick manifold"??? this is the only place where i could see something new and cool in this engine. perhaps a 6-1-2 or 6-2 tubular equal length manifold of some sort? looking at pics of the N55 manifold, you can definitely see that its a mass production design...
      08-31-2010, 02:07 PM   #4
Elsabor67
aiming for 450.....
Elsabor67's Avatar
Drives: Totaled :-(
2009 135i  [10.00]
Is there a reason that the N55 doesn't have the second set of cats??
Quote from Ezeedee regarding car mods:
"you're only done when you sell the car "
      08-31-2010, 02:16 PM   #5
1978.530i
Drives: BSM 1M
Did SCOTT specifically say it would be a 'hybrid' between the N54 and N55? I didn't remember he specified those two engines. Is a 'hybrid' between the N54 and something else possible?
      08-31-2010, 02:18 PM   #6
Madozu
Madozu's Avatar
Switzerland
Drives: 1M / M3 E36 3.2 6MT
I also tried to figure out what Scotts two posts about the engine/powertrain beeing a hybrid could mean:
Originally Posted by SCOTT26 View Post
I am going to give you a clue.... The 1M powertrain is a Hybrid.
And when I mean Hybrid do not think of the current meaning of "Hybrid" - ie Alternative power , Electricity etc.... and use the original meaning of hybrid.
" When Two seperate entities become one".
Remember BMW evaluate every idea to determine what is the solution?
The best way to describe the engine of the 1M is a "Hybrid" but in the original form of Hybrid, nothing to do with "alternatives", but it is not a straightforward transplant.
If it's not a straight-forward transplant it could also be based on the N54 with some modifications like larger turbos, changed manifold, changed air intake system, changed/better inter-cooler.
Still trying to figure out how it's possible to feed the 4 intakes of 2 twin-scroll chargers from 6 cylinders ...
      08-31-2010, 02:19 PM   #7
southlight
southlight's Avatar
1537
Drives: X3M
You're right, he didn't mention that. What else could he have meant?
Best regards,
south
      08-31-2010, 02:23 PM   #8
madfast
2 twin scroll turbos would be unnecessary... overly complicated...
2 small variable vane turbos? ah, now that's something
      08-31-2010, 02:26 PM   #9
Madozu
Madozu's Avatar
Switzerland
You're right, this would make more sense
      08-31-2010, 02:30 PM   #10
Simsims
Drives: 119/220
you can clearly see the twin pipe's brackets
VO 1M - everything except sunroof
RIP BSM 135i 2009-2011
      08-31-2010, 02:32 PM   #11
02fireman
02fireman's Avatar
Drives: Twistys
I did read a while back that BMW was working on a quad turbo 4cl. Could they have slapped more turbos on the 6 or maybe how about twin sequential, taking the turbo off the N55 and adding another (one N55 turbo on each side).
Z4M Coupe 6MT Monaco Blue #13/36 ...Keeper...
Z4 3.0 6MT ...Keeper...
2OO2 5MT ...Keeper...
335i 6MT Montego Blue M-Sport (Retired),X535d Vermillion Red/Saddle (Retired)
      08-31-2010, 02:34 PM   #12
Madozu
Madozu's Avatar
Switzerland
This Wikipedia article about Variable Geometry Turbochargers is worth reading. Especially the first section that mentions the problem of exhaust pressure at high rpm ...
      08-31-2010, 02:36 PM   #13
cstavaru
cstavaru's Avatar
313
Drives: 2009 335i M Sport Sedan 6MT
The 1M will surely have a modified air intake compared to the regular N54, because the Z4 35is also has this in order to produce 340hp. But is this enough to use "hybrid" ? I don't think so...
      08-31-2010, 02:37 PM   #14
PrimoM3
Chemofski
PrimoM3's Avatar
Drives: '13 X5M
I'm betting it's going to be a standard N54 single scroll, twin turbo, but with better cooling (larger center intercooler and maybe an additional engine bay one, plus an oil cooler), and a new special intake system like the one used on the X6M. Those changes in addition to the remapped software would likely net the ~345 hp that's been suggested. Right?
'13 Individual Frozen Brilliant White ///M3 Coupe
Ordered 2/15/12 | Euro Delivery on 9/21/12 | U.S. Redelivery on 12/6/12 | Motor Dead on 7/15/13
'13 Space Gray/Mugello Red X5///M
Pavement Punisher | Snow Muncher | Family and Board Hauler | Roadtripper
      08-31-2010, 02:44 PM   #15
Beach
Beach's Avatar
Drives: 2011 135I
I don't see why they would revert back to the N54. They have put so much into the development of the N55 and have discussed using it in other future vehicles. Theoretically in our 135's N55 produces the same BHP and Torque as the N54. I think it would be easier to make the reliable power gains that should be necessary to put an M badge by using the N55. Just my thought.
      08-31-2010, 02:48 PM   #16
pavelitto
pavelitto's Avatar
20
Drives: 135i Performance
I spoke while before the 1M was confirmed with some BMW insiders/experts and they said that the n54 engine was very likely designed by m gmbh because of its complexity and it was a come back to turbo engines for bmw after a while so they invested quite heavily into it to make sure its a good one (didn't want to fail at this attempt)
So I would assume M gmbh used this engine again as a basis for the 1M
The N55 as I was told is not as good as the N54 and represents cost cutting for mass production engine from BMW.
Just the thought
135i Performance
      08-31-2010, 02:58 PM   #17
Simsims
Drives: 119/220
1M Hybrid engine... logical hypothesis
Could it be between an N54, and turbos from BMW turbo diesel engines?
Technically if it's still twin turbo (since we saw exhaust pipes from the pictures), then it would only make sense to go either
- variable vane
or
- different size
so that top end power isn't shot due to the small snails unable to provide sufficient air.....
which comes to this page:
This is from bmw tech guide
Variable Twin Turbo technology takes the BMW four and straight six-cylinder diesel engines to unmatched levels of performance. It dual-stage design enables the engines to achieve performance figures that previously only larger eight-cylinder engines could reach. Emissions and fuel consumption, however, are impressively low.
Innovations such as common rail direct injection and exhaust gas turbo charging with variable turbine geometry have driven dramatic improvements in the performance of diesel engines.
The introduction of BMW's dual-stage turbocharging system, Variable Twin Turbo, represents another quantum leap in diesel engineering. This technology delivers a performance boost of 25 per cent, and enables instant responsiveness even at low engine speeds - as well as enormous reserves of power at higher revs.
The heart of the Variable Twin Turbo system comprises two turbochargers of different sizes. In contrast to the bi-turbo system, the two turbochargers do not operate parallel, but are activated at different points. Precisely coordinated, they run individually or together, increasing the pressure of the intake air to the optimum level. The greater pressure of the intake air enables a more effective combustion of the diesel fuel in the cylinder.
At lower engine speeds, the intake air passes through the inactive larger turbocharger into the active smaller turbocharger, which increases the air pressure. At medium engine speeds, the larger turbocharger becomes active, forcing air under pressure into the smaller unit, which increases the pressure still further. At higher engines speeds, the larger turbocharger alone forces air into the cylinders.
Despite these impressive dynamics, the fuel consumption of the Variable Twin Turbo diesel engine is exemplary low, according to EU standards. The standard diesel particle filter ensures that strict EU4 emissions standards are met.
      08-31-2010, 03:13 PM   #18
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Maybe because this is going to be a short production run and the N55 will be reserved for the upcoming M3?
      08-31-2010, 03:20 PM   #19
randomquickness
Drives: 996tt
possible but with the space constraints and knowing the stock snails can handle 380 crank hp wih ease, I dout it.
      08-31-2010, 03:34 PM   #20
Simsims
Drives: 119/220
just because it CAN doesn't mean it should.
M also takes into account the requirement for longevity etc..
      08-31-2010, 03:51 PM   #21
dmboone25
dmboone25's Avatar
4972
Drives: 2024 Golf R / 2022 718 Spyder
2007 E92 328i  [10.00]
2007 328i  [10.00]
That seems the most likely reasoning. Not enough time to sort everything out now....SCOTT even confirmed the N55 couldnt be used in the E82 1M because the valvetronic issues couldn't be sorted out quickly enough.
He did confirm though that the N55 is still slated to be the basis for the F30 M3....
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
      08-31-2010, 04:38 PM   #22
BForbes
Moderator
BForbes's Avatar
Bahamas
559
Drives: BSM 135i/AW E90 M3
Nice work, South!
- 04 Honda S2000(gone)
1addicts
