BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
      09-21-2010, 12:21 PM   #1
Tanft
Drives: E92
      09-21-2010, 04:56 PM   #2
mexicanmike
Drives: 09 E93 Jerez Black
Little different, but here you go http://www.m3post.com/forums/showthread.php?t=419809
      09-25-2010, 11:49 AM   #3
LateBraking
Drives: Relatively Quick.
From my searches, it's extremely similar. The V1 hardwire DIY that I made actually made use of a lot of information from discussions on Passport hardwires. If you're using the fuse tap method, fuse slot and everything should be the same, so only difference should be cosmetics, and how the passport gets powered (i.e. V1 uses hardwire block. If Passport does too, then its the exact same.)
      09-25-2010, 05:19 PM   #4
ersin
ersin's Avatar
Drives: 17 YMB F80 M3
Originally Posted by mexicanmike View Post
That's for the 9500ci which has a remote detector unit outside the car and includes a laser jammer. The 9500ix is completely different and is a dash/window mounted detector-only unit like the V1. Get the Escort 9500ix direct wire cord to wire directly in to the fuse box or other power source. Or get the Escort smartcord to mount the mute button remotely. Using one of these makes the hard-wire installation identical to that of the V1.
Cheers.
2017 F80 YMB.
      09-25-2010, 06:43 PM   #5
mexicanmike
My bad, thanks for the correction
      09-28-2010, 09:00 PM   #6
Tanft
Drives: E92
      10-16-2010, 12:12 AM   #7
Ryboy98
Ryboy98's Avatar
28
Drives: 2009 M3 Coupe
Originally Posted by Tanft View Post
I've seen a lot of V1 hardwire threads, but no 9500ix hardwire threads anywhere. Is this because the 9500ix is more difficult to hardwire because of its extra mute button?
Anyways, if anyone knows someone who could do a good install job in the SoCal area, or a good DIY, I would love it. Thanks a lot!
Don't know if you saw my DIY on a 9500i, but this has worked well for me. Plus feels kinda cool when the alert goes off and I mute it, I feel like I'm in an airplane cockpit, flashing lights on the ceiling and pushing buttons up there. And it keeps everything out of the way.
http://www.m3post.com/forums/showthread.php?t=352466
I'm going to bump my thread also for the heck of it maybe help some others too. Try it, I think you'll like it.
Ry
m3post
