BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
      10-24-2010, 12:45 PM   #1
pinmagic
The Only Sane One Here
pinmagic's Avatar
Drives: 135i Convertible
Trying to Rename an Album in iDrive - What Am I Doing Wrong???
Thus far, I've stored 2 CDs (albums) in my "Music Collection" (on the car's hard drive). One showed the title of the album properly, but the other (the soundtrack from Wicked - an original disc, not a copy) shows only a bunch of rectangles. So I'm trying to rename it, but it's not working.
And yes, I . It says to choose "CD/Multimedia," then "Music Collection," then highlight the desired album, and open "Options." So far, so good, but then "Rename Album" is blanked out, so I can't select it. I have the same issue for BOTH albums I stored. I can select "Delete Album", but not "Rename Album."
The OM says you can't rename an album if it's currently playing, so I made sure the OTHER album was playing when I tried this. Then, I tried turning off the system (using the pushbutton on the dash). Still no luck.
Am I missing something here???
2011 135i VERT SGM/SB/MOONLIGHT - ED - with every single friggin' option they offered.
      10-24-2010, 02:31 PM   #2
pinmagic
pinmagic's Avatar
Originally Posted by maxnix View Post
Hell, I didn't even no one could do this. I have a couple of "Unknown Albums" because they are a custom burn I loaded into the hard drive.
Give it a try, and let me know if you have better luck than I did.
      10-24-2010, 02:54 PM   #3
Haywood
I know a thing or 2 about a thing or 2...
Haywood's Avatar
3104
Drives: E36 M3 Coupe, e39 M5, i3s
2003 BMW e39 M5  [0.00]
1997 BMW e36 M3  [0.00]
What's a CD?
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1
1997 Alpine White e36 M3 (the old gal)
2013 Mineral White e92 M3 (sold )
2014 Carbon Black 650i M-sport (sold)
      10-27-2010, 08:16 PM   #4
pinmagic
pinmagic's Avatar
Can someone PUH-LEEZ try this, and let me know if it works??? Thanks.
      11-01-2010, 11:37 AM   #5
pinmagic
pinmagic's Avatar
Thanks for testing that!
I may have figured it out, tho I'm going to talk to my dealer about it.
The manual says you can't rename an album that's currently playing, but that appears to be incorrect. Instead, it appears that you can only rename an album when you first load it into the hard drive (whether it's playing or not). Apparently, after a certain amount of time - or, more likely, when you start loading another album, you lose the ability to rename it. (Still trying to figure out exactly what ends the sacred "window of opportunity to rename.")
So that means that, to rename an album down the road, I'll have to delete it, and then reload it.
I cannot imagine why you wouldn't be able to do that at any time. Makes no sense. Honestly, I think the iDrive was programmed by the proverbial roomful of monkeys.
      11-08-2010, 07:34 AM   #6
pinmagic
pinmagic's Avatar
Spoke to the dealer's head tech about this on Saturday. He tells me that it's a function of the original CD - some allow you to rename the album, and others are "locked down" electronically, preventing you from doing it. I'll play with it some more to see if I can confirm that.
1addicts
