New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      03-25-2011, 04:11 AM   #1
mrboon
mrboon's Avatar
Drives: Speeeed
Cool JB4 USB Cable Installation
Hi guys, i just got JB4 installed, and I also use the USB data cable to connect it to my laptop. Now i would like to have a more permanent solution, so I would like to run a cable from the ECU unit to the glove box, or somewhere near there.
I looked under the hood for a while, but I dont see any easy access. Does anyone ever installed something similar in their Z4? If so, do you have any tips?
      03-25-2011, 04:38 AM   #2
jannisa
jannisa's Avatar
55
Drives: Z4 Sdrive35i
It 's kind of pita to run the cable through the ecu box into the cabin via the intergrated tunnel which should be a 15 min job on a 335. I tried it myself but gave up and handed it over to my technician who got it done in an hour. A must for your piggy imo.
      03-25-2011, 06:36 AM   #3
mrboon
mrboon's Avatar
Drives: Speeeed
As far as I can tell from pics is the ECU box on the left side of the car with the 3 and 1 series. The Z4 has it on the right. This means its not on the side where the glove box is making it a lot harder to do the cable.
      03-25-2011, 07:21 AM   #4
jannisa
jannisa's Avatar
55
This is not the hard part. The difficulty is that on the Z4 the tunnel is just too tight. On the 335 it practically passes through by itself. Leading the cable from inside the drivers side into the glovebox is a 2 min job but you need a lot more time and patience to pass it from the ecu box into the cabin. Been there done that.
      03-26-2011, 11:57 AM   #5
mrboon
mrboon's Avatar
Drives: Speeeed
I managed to do it turned out to be easier than expected.
      03-27-2011, 04:34 AM   #6
jannisa
jannisa's Avatar
55
There is a tunnel with a fan to cool the ecu box. I wouldn't pass it through there.
      03-27-2011, 08:22 AM   #7
integraworks
integraworks's Avatar
Drives: 2010 Z4 s35i
Question: on the Burger / JB4 website they encourage you to purchase their USB to RS232serial cable and state that use of any other similar cable can cause damage to the JB4 unit. What is your experience with this? Is the JB4 cable really any different from any other cable?
      03-28-2011, 09:48 AM   #8
mrboon
mrboon's Avatar
Drives: Speeeed
Im not sure, i just bought their cable. Its a very basic one, usb to a 3 pin out. should be easy to make yourself i think
      03-31-2011, 03:31 PM   #9
persian54
persian54's Avatar
Drives: M760/G83M4
is $30 really worth the risk?
zpost
