New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      10-16-2011, 04:33 PM   #1
Constant.S
Resistance is futile...
Constant.S's Avatar
54
Drives: BMW Z4 E89(N54)
7 speed DCT tuning?
Today i went with a buddy and his 35is DCT on a meeting on a test strip that we meet up every now and then and "play" and since my 35i is "under development" my friend asked me to drive his on some runs with an Audi TTS, among other cars, since im more experienced. Now my car is a DCT too so im familiar with the gear changing but this time i used both manual gear changing and also did some launches letting the ECU in sport+ and S mode do the changes and noticed that the transmission on automatic actually changes gear a little over the beneficial RPM range, around 7000(I manually change around 5900-6300 for optimal performance).
So my question to the "technically inclined" is: Is there a way to reprogram the Transmissions ECU for optimal gear changing? Cause that would make a DCT car a real Killer on the strip or anywhere else utilizing launch control and just... Stepping on it. Maybe ESS, with their experience on the M3's DCT tuning, can chime in?
An ounce of performance is worth pounds of promises.
      10-17-2011, 10:07 AM   #2
sales@ESSTuning
sales@ESSTuning's Avatar
391
Drives: ESS M3 / M4
We have tuned the DCT in the M3 which is similar but have yet to play with the Z4.
      10-17-2011, 11:31 AM   #3
Constant.S
Constant.S's Avatar
54
Thanks Roman Is there any work in progress or plans for our Gertrag Powershift or tuning on the gearbox's logic board on N54 platforms, or is it strictly for the M3?
I heard some really REALLY good critics about the tuning you made on the M3's DCT especially combined with your VT2 supercharger systems
      10-18-2011, 11:34 AM   #4
sales@ESSTuning
391
Drives: ESS M3 / M4
When we get some time we will take a look at the transmission control and see if it can be modified.
      04-05-2012, 06:34 AM   #5
Ramjet
Drives: z4 35i
any progress on this?
      04-05-2012, 10:24 AM   #6
wdlfbio
Drives: 2013 4S, 2015 3500 HD Dually,
The E89 35is with DCT will take ESS stage 1, but not stage 2. Per ESS last week. Im about to buy their flash for my new 35is, and add a valet tune to it.
'16 235i
'15 3500 HD Dually
'13 C4S
      04-05-2012, 12:24 PM   #7
SHADOW4
SHADOW4's Avatar
Sweden
44
Drives: Tanzanite M4 2018
2010 E89 35i  [0.00]
What do you mean? Have I missed something?
      04-05-2012, 03:47 PM   #8
Constant.S
Constant.S's Avatar
54
Stage 1 for the "is" model is the same peak power as the stage 2 for the normal 35i anyways. He is talking about the ECU tuning not the DCT tuning =)
      04-05-2012, 08:51 PM   #9
wdlfbio
I didn't figure the question was about tuning the DCT, rather what ESS had available for the E89 w DCT. I asked them the same question directly and got the below response. But your r right, it's odd that they call it the stage 1 when it makes the same power as their stage 2 for non DCT trannies.
Per Asbjorn w ESS-
"The DCT version of the Z4 3.5is can only take the power of the Stage 1 (400chp, ~350rwhp). Any more and the DCT clutches can not handle it in the long run."
'16 235i
'15 3500 HD Dually
'13 C4S
      04-06-2012, 03:06 AM   #10
SHADOW4
SHADOW4's Avatar
Sweden
44
2010 E89 35i  [0.00]
Per Asbjorn w ESS-
I think there is an typo here as Stage1 gives around 355 chp and 480 tq and Stage 2 390-400 chp and 550 tq, anyway as i remember it. Ceartinly can feel the difference between the stages.
Getrag can take 600tq what i have learned ( there is a link somwhere on the forum)
Whatever is true, parts will always deteriorate when used. I belive how you use it will be more of a factor of how long parts will hold.
I am still confused
Manual says don't use "launch control" to much as it increases the load on the car, even without ecu tunes!
      04-06-2012, 05:08 AM   #11
Aoikase
Drives: E89
Constant.S
http://www.getrag.com/en/252
the linked you post before.
      04-06-2012, 07:02 AM   #12
SHADOW4
SHADOW4's Avatar
Sweden
44
2010 E89 35i  [0.00]
In my 2010 there is an Getrag 7DCI600 wich apperantly have been replaced with the newer 700 models in newer cars. Congrats to all of you!
Seems Getrag does not have any specs of the 600 on there website anymore.
      04-06-2012, 10:12 AM   #13
Aoikase
Drives: E89
I assumed it is going to be very expensive, and not sell for individual?
      04-06-2012, 09:31 PM   #14
wdlfbio
I am still confused
That was the email from ESS. Here is the info directly on their website, for hte E89 35is.
http://www.esstuning.com/products/ES...-Software.html
Product Description
ESS E-FlashFlash N54 "is/1M" ECU software is a result of extensive testing and exact calibration of ECU parameters to allow conservative performance gains on an otherwise stock car. The ESS 335i software is developed and tested in extreme heat in the Arizona desert as well as extreme cold temperatures in Scandinavia. The end user can select between 2 different power levels and cat/no cat in the DirectFlash unit. ESS E-Flash also includes full engine diagnostic functionality and code clearing capabilities.
DirectFlash Stage 1 :
Top Speed Governor: Removed
RPM Limit: 7200RPM
Fuel requirement: 91US
Horsepower: 400 DIN (Stock 335) - 390 DIN if used with stock intercooler
Torque: 550NM
Normal whp range on DynoJet: 345-365whp
'16 235i
'15 3500 HD Dually
'13 C4S
      04-07-2012, 02:27 AM   #15
Asbjorn
Asbjorn's Avatar
China
90
Drives: Z4 N54 DCT (VTT GC lites)
Is performance really better when shifting at lower revs? I rarely rev to red-line myself, but are we sure it does not offer better drag strip performance to do so? I know the torque will drop off at higher revs, but is the curve really so steep that rwtq above 6300 drops below that of lower revs in next gear and for all gears?
      04-07-2012, 05:23 AM   #16
SHADOW4
SHADOW4's Avatar
Sweden
44
2010 E89 35i  [0.00]
Ok, now I see..........
They removed the unneccesary stage for the 35iS as it's almost the same as Stage1 for the 35i.
Still for the 35i:
Product Description
ESS E-FlashFlash N54 ECU software is a result of extensive testing and exact calibration of ECU parameters to allow conservative performance gains on an otherwise stock car. The ESS 335i software is developed and tested in extreme heat in the Arizona desert as well as extreme cold temperatures in Scandinavia. The end user can select between 2 different power levels and cat/no cat in the DirectFlash unit. ESS E-Flash also includes full engine diagnostic functionality and code clearing capabilities.
RPM Limit: 7000RPM
Fuel requirement: 91US/95Euro
Horsepower: 355 DIN (Stock 306)
Torque: 480NM (Stock 400NM)
DirectFlash Stage 2 :
RPM Limit: 7200RPM
Horsepower: 400 DIN (Stock 306) - 390DIN if used with stock intercooler
Torque: 550NM (Stock 400NM)
      04-15-2012, 09:46 AM   #17
dhplachy
dhplachy's Avatar
Iraq
Drives: 2012 Z4 35is
ESS tune on a 35i vs a 35is
I noticed that the ESS website only mentions the 35i and does not differentiate the 35is. It was my understanding that the 35is has a different intercooler.
The 35is also has an overboost which I understand is replaced by the ESS tune to not be limited to the 7 seconds, etc.
It would be nice if the ESS website gave more information about the 35is.
      04-16-2012, 01:11 AM   #18
wdlfbio
They show info for the 2011 35is.
'16 235i
'15 3500 HD Dually
'13 C4S
      06-01-2012, 05:33 AM   #19
hansd
Drives: E89 35is
I agree, would be good if Roman could shine some light on the matter
      06-25-2012, 11:17 PM   #20
SpeedDemon7
SpeedDemon7's Avatar
70
Drives: 2015 F80 M3 Austin Yellow
I wish there was some tuning capability to it. I was really having a hard time at the drag strip. Since the 35i does not fully disable both traction systems I was not able to use it very effectively, fastest time I ran was 13 flat with a 2.6 60' at 111.0. Got home and I finally figured a DIY way to launch the car. Kinda tricky and takes a lots of practice. If you press the traction once, and hold it to turn off DSC, then put the car in M1 mode by putting shifter to the left, I was able to fully press the accelerator till it hit the button at the bottom of the pedal, then the revs would increase without engaging the transmission, its a very small opportunity but if you tap the brake while pumping the accelerator about twice to hold it at about 3000 rpm for about 1 or 2 secs then launch. Was working pretty well at a empty lot I was practicing. Def going back to the strip aiming for low to mid 12s where the car should be.
Damn GTR
2015 F80 M3 DCT : JB4 : Gintani DP : METH : BMS INTAKES : Upgraded Turbos : GTS DCT Flash
11' Z4 35i Procede REV 3 SOLD
2007 e90 335i 6MT:Procede REV 3: Raceland 2.5": VRSF 7":VRSF CHARGE pipe: Walbaro 255 inline: ACT 6 Puck: 100% e85
Garage: 2015 M3 : 2007 M5 : 2016 X1 : 2003 X5
      06-27-2012, 11:34 AM   #21
z4z4z4
z4z4z4's Avatar
Drives: 2002 M3
Damn GTR
I have no DCT dragstrip experience, but I'd like to hear from you after trying the DCT launch control program per the owner's manual:
Launch Control is available when the engine is
at operating temperature, i.e., after driving continuously
for at least 6 miles/10 km.
1. With the engine running, depress the brake
pedal with your left foot.
2. Activate the SPORT+ program of the Dynamic
Driving Control, refer to page 78.
3. With the vehicle stationary, activate manual
mode and select first gear.
4. Press the accelerator all the way down. The
engine speed when driving off is controlled.
A flag symbol appears in the instrument
cluster.
5. The vehicle accelerates when you release
the brake pedal. Keep the accelerator
pressed all the way down.
6. The transmission shifts up automatically as
long as the accelerator is pressed all the way
down.
Launch Control only becomes available again
after a certain distance has been driven.
ALSO, I'd like to know if you're logging your JB4 at the track?
You may be pulling timing from not turning off DSC with a long push of the button, which conflicts with the use of launch control which requires Sport+. Traction control activity is interpretted as engine KNOCK by JB4 and the tuner pulls timing to protect the engine.
Sold 2011 Z4, kept 2002 M3
PM for various e89 parts 4sale.
      06-27-2012, 11:48 AM   #22
Vintage
Vintage's Avatar
Drives: BMW G80 (MT), 718 Spyder
you mean to say - you engaged the car's launch control? did the checkered flag come up and the RPMs held automatically at 4k?
dct, n54, performance, transmission, tuning
zpost
