07-10-2013, 01:21 PM | #1 |
Rep 31
added spacers front and rear to fill the gap
07-11-2013, 06:51 PM | #2 |
Vanilla Gorrilla
31
Rep 610
I hate to say it but looks like you could use another 25mm or so in the rear.
X5M, Eisenmann exhaust, 22" HRE wheels, catless down pipes, Stage II tune/X5 Diesel, Lowered & Tuned
07-11-2013, 10:28 PM | #3 |
Rep 50
Something is wrong... 50 mm rear should have moved you way past flush.
A 25 mm spacer on the rear with factory 20's should be flush with flares Looks like you may mot be running a staggered set up??? Other than the odd look to the rear wheels your X looks great |
07-12-2013, 01:12 PM | #5 |
Rep 31
i'm an idiot, i meant a 25mm spacer out back. i had to get 50mm lug bolts from EAS to make them fit.
i know the rear could use more but i had a hard enough time finding a spacer as big as 25mm. i use to run the spacers on my M3 until i got new wheels. so i just used what i already had. it will have to work until i get much wider wheels to fill the gap, and even then i think i will run some sort of spacer to make it more flush. |
07-12-2013, 01:27 PM | #6 | |
Rep 6,125
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 Last edited by isugoo; 07-12-2013 at 08:37 PM.. |
07-12-2013, 08:16 PM | #7 | ||
Law Enforcer
25108
Rep 22,288
Drives: '22 Chalk Gray Porsche C2S
08-10-2013, 09:48 AM | #9 |
Rep 11,136
Just some constructive critisism: your tires are not wide, yet you are pushing them further to the "outside". Visually, there is little improvement until you get larger wheels with fatter tires. When you have fender flares, you want at least 315s in the back. It might have been a better option to not have fender flares until you were able to have the wheels at the same time.
08-10-2013, 08:09 PM | #10 |
Rep 31
all in due time. it's the wife's ride so i am not as concerned as if it were the car i drive daily. i had to take the spacers off anyway b/c they caused a vibration at highway speed.
thinking about getting a stud kit and spacers designed for the X5 for better balance. the ones i had on there were from my M3. |
08-11-2013, 12:24 PM | #11 | |
Law Enforcer
25108
Rep 22,288
