03-24-2014, 06:41 PM | #1 |
Слава Украине!
2335
Rep 2,443
Trunk Liner Modifications
If I ever get the time to install my Koni rear externally adjustable dampers, I'd like to modify my trunk liner to allow easy access to the adjuster.
Making the hole in the liner is the easy part. What I'd like is an elegant way to cover said hole. Suggestions welcome. |
03-24-2014, 11:44 PM | #2 |
Rep 143
The rears adjust from the top? that's interesting...Is the adjuster a 6 point socket or do you need to get in there with a pin or pliers? Pictures of the strut would be a great help.
03-25-2014, 07:56 AM | #3 |
Слава Украине!
2335
Rep 2,443
03-25-2014, 08:43 AM | #4 |
Rep 639
I would like to know what you figure out. I'd like to do something as well to make accessing the top of the damper easier. Some sort of black plastic cap to cover the hole wouldn't look too bad.
2009 BMW LeMans Blue 135i/Dinan Stage 2 tune/Alufelgen SF-71s/M3 suspension components/Koni Sport adjustable dampers/ETS FMIC/M3 paddle shifters/Alpina B3 TCU flash/VRSF charge pipe
03-25-2014, 08:45 AM | #5 |
Rep 2,388
Drives: M2 Competition
You can make a cutout the acts as a flap that you can close to access the adjuster. This is how I did it on my car.
03-25-2014, 08:46 AM | #6 |
Resident Tamed Racing Driver
298
Rep 4,697
I would imagine one of the easiest ways to do it and keep NVH down would be to cut the hole the same size as the rubber top that goes on the sound deadening above the rear shock tower and buy an extra set to pop in.
Having a hard time finding it on RealOEM though. I would have thought it would have been in Vehicle Trim/Insulation...
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
03-25-2014, 08:54 AM | #7 | |
European Editor
10607
Rep 22,992
Here you go Stig. Pick a plug. http://realoem.com/bmw/showparts.do?...71&hg=51&fg=80
03-25-2014, 09:16 AM | #8 | |
298
Rep 4,697
03-25-2014, 10:00 AM | #9 |
Rep 639
That's an excellent idea.
03-25-2014, 10:26 AM | #10 |
Rep 2,388
03-25-2014, 10:48 AM | #11 |
298
Rep 4,697
True, but the plug will give you better access.
Also, you are missing a trunk liner pin.
03-25-2014, 11:47 AM | #12 |
Rep 2,388
Plug will give you less access (size comparison).
St|g, That was back when I had to double check seals so I was taking it on and off every couple weeks to ensure that my ancillary electronics weren't seeing water. OP, If you figure out a "telescopic" type tool that grabs the top of the adjustment knob (but only just) so I don't have to deal with the front brace bar, I'd really appreciate it. |
03-25-2014, 12:05 PM | #13 |
Rep 257
Thanks for the pics venom. Can you get the rubber cap back in there with that opening, or just leaving it off?
I took the truck liner out on my 135i convert this weekend to install KWv3's this week. I dont want to get in the habit of taking that damn liner in and out. (with a convert I think its even more of a PITA that the coupe) |
03-25-2014, 12:14 PM | #14 |
Слава Украине!
2335
Rep 2,443
Thanks, guys. Lots of good suggestions. I also found plugs similar to the BMW items on McMaster-Carr that go all the way up to 4 inches.
"Flexible Plastic Plugs" 3 inch, pack of 25 is only $13.63. http://www.mcmaster.com/#hole-cover-plugs/=r8z9tg |
03-25-2014, 12:17 PM | #15 |
Слава Украине!
2335
Rep 2,443
03-25-2014, 12:34 PM | #16 |
Rep 2,388
03-25-2014, 12:35 PM | #17 | |
Rep 2,388
03-25-2014, 01:56 PM | #18 |
298
Rep 4,697
He's referring to the rubber cap I mentioned. I must be misremembering it as I was under the impression it was ~3 inches or more in diameter.
03-25-2014, 02:03 PM | #19 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
03-25-2014, 02:07 PM | #20 | |
Rep 2,388
Either way works. Mine is just lazier Edit: that last post above this one shows how you would make a circular cut if you wanted to use st|g's rubber cap method Last edited by Venom; 03-25-2014 at 02:12 PM.. |
