02-13-2017, 02:32 PM | #45 |
Rep 2,981
Drives: 2013 BMW F30 EBII
I used a jewelers flat head screwdriver and carefully pried each one off. It takes time and you have to go slow and have patience.
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread |
Nomana1466.00 |
02-13-2017, 02:48 PM | #46 |
Rep 3,863
02-13-2017, 03:51 PM | #47 |
Rep 3,539
Pry the teeth away from the post. I inserted a flat head screwdriver in the slots and twisted the head to pry the center of each tooth away from the post. It doesn't take much.
Nomana1466.00 teachasumthin326.50 |
02-14-2017, 01:57 AM | #48 | |
Schmollbraten
12512
Rep 1,985
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
Nomana1466.00 |
02-14-2017, 02:43 AM | #49 | |
Rep 1,637
I wont try to make excuse here but I did seach but missed this diy. All nice works Appriciated |
02-20-2017, 01:40 PM | #50 |
Rep 7
Wow, this carbon looks really great, excellent job!)
Dang3r12512.00 roll_the_dice507.00 |
02-23-2017, 09:50 AM | #51 |
Rep 231
Looks great bro! Keep up the good work modifying your car!
02-23-2017, 02:20 PM | #52 |
Rep 2,981
Thank you very much!
Thanks, getting where I want it to be slowly but surely.
My Build Thread |
03-23-2017, 12:15 PM | #53 | |
Rep 87
03-23-2017, 02:04 PM | #54 |
Rep 2,981
I put a small screwdriver behind the gray plastic and popped one corner, then I could slowly pry the piece loose going around the edges.
The black trim piece that holds it can be removed when the steering wheel is off ...
My Build Thread |
UKF302524.00 |
03-23-2017, 02:39 PM | #55 | |
Rep 87
03-23-2017, 02:45 PM | #56 |
Rep 2,981
Mine came off pretty easily...so maybe I got lucky.
My Build Thread |
03-23-2017, 03:27 PM | #57 | |
Rep 3,539
To remove the airbag there are two holes at the 4 and 8 o'clock positions on the steering wheel near where it connects to the column. I use a large diameter punch to push the spring in till it unlatches the airbag on that side (you'll need to apply a bit of pulling pressure on the bag to get it unsat once the latch clears). Note that if you make contact between the rear of the bag and the rest of the steering wheel with the punch it will sound the horn. Once unlatched, unplug the single connector on the inside of the steering wheel (not the connectors on the rear side of the airbag). You should then see the two screws holding the larger trim piece at about the 3 and 9 o'clock positions. |
03-23-2017, 09:47 PM | #58 |
Rep 2,981
I couldn't remember about taking the black SW trim off...but you are correct...airbag off, then it can be unscrewed. Thanks for the reminder...
My Build Thread |
03-24-2017, 10:51 AM | #59 |
Rep 370
Drives: 2013 AW 335i
I really like what you did with the trim pieces! I'm thinking of wrapping my trim pieces with 3m carbon fiber wrap. What's the specific product that you used?
2013 Alpine White 335i -M Sport/// Akrapovic Catback Exhaust/// KW Street Comfort Coilovers/// BMS intake/// JB4/// ER front mount intercooler/// ER Charge pipe/// ER catless downpipe/// 18" Apex Arc-8 in Anthracite/// Michelin Pilot Super Sports
03-24-2017, 11:54 AM | #60 |
Rep 2,981
Thanks...I used real carbon fiber, no 3m vinyl, epoxy resin, and automotive clear coat...then wet sanded and polished.
My Build Thread |
WillSkill172.00 |
03-24-2017, 02:01 PM | #61 | |
Rep 3,539
I did a mockup with some, and it looks good. |
WillSkill172.00 |
03-24-2017, 02:56 PM | #62 |
Rep 166
Hi roll_the_dice,
Nice work on the carbon fiber! I was planning on doing this cf wrapping myself because I don't like the performance trims because of the alcantara. Did you wrap the carbon around the edges of the trims or did you stop right at the edge? I'm thinking of stopping at the edge and not around it because of fitting but i'm afraid it might get loose after a while. Any tips? I don't have any recent experience with raisin but i'm a quick picker-upper... Kind regards, KingpinRCR |
03-24-2017, 11:21 PM | #63 | |
Rep 2,981
Don't wrap it around to edges that don't show...it will make it bulky and really serves no purpose. If the wood shows on the OEM trim it gets covered in CF...otherwise no point.
My Build Thread |
05-05-2017, 11:20 PM | #64 |
Rep 75
Absolutely gorgeous!
05-05-2017, 11:36 PM | #65 |
Rep 2,981
My Build Thread |
05-06-2017, 06:37 AM | #66 |
Rep 3,863
